Yannick, et. al.
Well I’ve isolated my sample swap/delay problem. After getting the same failures in both Wavelab and Nuendo, I moved my attack down a notch to the ADDA box. Just as a wildass guess I reconfigured the clocking on the ADI-8 DS ( the ADDA box) and the problem disappeared. When it was failing, I had the RME ADI-8 DS externally clocked from the word clock output of the RME Hammerfall Digiface via 3ft. of 75 Ohm terminated coax. Simply changing the clocking on the ADI-8 DS from ‘EXT’ to ‘INT’ cleared up the problems (all of them). On restoring it back to external clocking, the problems reoccurred.
Well, Dan always said it would work better on internal clock, right Dan? I’ve e-mailed REM and they are looking at it. Maybe I can get some work done now....
Joe Crawford
