Pages: [1] 2 3  All   Go Down
Author Topic: L2 vs. MD4 vs. clipping test #6 (TS - rock)  (Read 14807 times)
bblackwood
« on: January 04, 2005, 12:11:34 PM »
Time for test #6! Here are the links to download three files (sierra, tango, and uniform) from Trevor Sadler. Download them and give them a listen, then come back and vote in the poll to tell us which one you think sounds 'better'. After a week or so (maybe more, maybe less), we'll release the answer of which is which...
links removed
[Warning - do not read further until you have listened - no reason to have someone else influnce your listening...]
Discuss...
Brad Blackwood
euphonic masters
bblackwood
Re: L2 vs. MD4 limiter test #6 (TS - rock)
« Reply #1 on: January 04, 2005, 12:12:42 PM »
No one can see what you vote for, so tell us what you think...
Also, feel free to post your thoughts about what you are hearing...
Brad Blackwood
euphonic masters
ATOR
Re: L2 vs. MD4 vs. clipping test #6 (TS - rock)
« Reply #2 on: January 04, 2005, 03:11:47 PM »
In ranking order from best to worst:
Tango
wider, more open more fizzle in the top. Doesn't have the limiter action like the others. This must be the clipped one.
Sierra
this was my reference file so not as wide and open as Tango but not as flat as Uniform. Best of the limiters. After listening some more this could become my favorite. From this file I prefer the quiet part over T and U.
Uniform.
This one is way too heavy limited for me, the whole mix clamps down, the snare almost disappears. Almost sounds as if it's played on the radio.
The pro of clipping is that the body of the mix doesn't change if a peak is 'limited'. You can clearly hear the effect of the limiters on the body of the mix with the other two masters. Maybe I'll do some experiments with clipping myself to see how it works out.
Pieter Vincenten - ATORmastering
Lee Flier
« Reply #3 on: January 04, 2005, 04:02:26 PM »
The only one I didn't think was total doo doo was the first one (Sierra).  It's much more open than the other two, and bottom end is tight and focused.  In Tango in particular, the low end almost totally falls apart, and in both Tango and Uniform the space sounds more "closed" and the whole thing just gets messy.
bobkatz
« Reply #4 on: January 04, 2005, 06:09:59 PM »
I couldn't bear to listen to these for long because I'm currently listening to the finest-sounding stuff in the world, a new album from Marley's Ghost, 9624 or 1/2" (we haven't decided yet which to use), absolutely open, clear, dynamic, pure, great performances, vocals are recorded naturally and in a real room not on top of the mike, a wonderful set of acoustic instruments and arrangements by the group, produced by Van Dyke Parks.
In contrast, Father, please forgive me, my ears took a shock listening to this test stuff. The compression/limiting is obviously part of the sound, the up front, edgy stuff. Well, anyway, after a period of ear-adjustment, I preferred Tango over Uniform because Tango sounds "wider". Sierra is far behind, very distorted and ugly. Ironically, I dropped Tango by 0.2 dB but it still wins.
Let the games begin.
There are two kinds of fools,
ammitsboel
« Reply #5 on: January 04, 2005, 07:17:04 PM »
Sierra:
Sounds a little "closed in" and distorted in the chorus.
Sounds processed(A little artificial maybe).
Tango:
Sounds a little "closed in" like Sierra but more distorted in the chorus.
Uniform:
More open sounding than the others.
The clipping is quite audible in the chorus.
The compromise for me lies in either sacrificing the open sound or get some clipping in the chorus.
...what i would use in a session depends entirely of what would suit the whole song and not just this clip.
-So no favorite from me!
"The male brain is designed for ecstasy" -Dr. Harvey "Gizmo" Rosenberg
J Schroder
« Reply #6 on: January 04, 2005, 08:10:14 PM »
Sierra and Tango seemed to overwhelm the vocal, making it an irrelevant distraction.  Uniform sounded like crap, but the song made more sense, lyrically.  Probably mixed by guitar player, or worse, a drummer... Very Happy
John
mastermind
« Reply #7 on: January 04, 2005, 08:45:30 PM »
I smacked this stuff a fair bit harder than I normally would (none of these were the version that was used on the CD, approved by the band), but again, as Brad points out, it's nice to compare the differences when the different limiters are being pushed a bit.
The actual cut for the CD was probably about 1.5db lower than these  in level.
It's interesting to see the different comments on this...
t
trevor sadler
_________________________________________
mastermindproductions
mastermind on facebook
charlotte, nc., usa
turtletone
« Reply #8 on: January 05, 2005, 09:34:26 AM »
sierra is the L2
Tango is clipped
Uniform is the MD4
not sure about S and T.
Tango wins here for me.
Michael Fossenkemper
TurtleTone Studio
info@turtletonestudio.com
www.turtletonestudio.com
ammitsboel
« Reply #9 on: January 05, 2005, 10:53:26 AM »
Hi mike  Smile
Are you listening with your ear plugs again?
turtletone
« Reply #10 on: January 05, 2005, 10:58:15 AM »
doh!
I thought everything sounded a little dull. Ahhh, that's better. I can hear myself think now.
TurtleTone Studio
ammitsboel
« Reply #11 on: January 05, 2005, 11:06:02 AM »
Mike...
You aren't releasing masters judged on only your ear plugs, are you?? he he...
zetterstroem
« Reply #12 on: January 05, 2005, 11:24:06 AM »
sierra: wamer than the others.... but soft.... almost undynamic ... and pumping a bit
tango: thin and digital but sounds more dynamic
uniform : thin and digital and a bit distorted... still... more attack in the drums
my guess is:
sierra = tc with too long release for my taste
tango = clipped  (needs tape and tubes)
uniform = L2 because of similar tonal balance to tango
i like tango best... although i miss some of the warmth of sierra... but i would NOT like a limiter to add warmth... that's what tubes and tape are for....
in general use i think the (software) L2 doesn't alter the tonal balance too much.... but it can distort (i mostly use 3mS release and NEVER arc)
by the way... when i tested the m6000 the shortest release time of the limiter was 15mS.... has that improved??? i rejected the units because of that!
Noting the music industry's complaints that illegal downloading means people are getting their music for free, he said, "Well, why not? It ain't worth nothing anyway." (b.dylan)
turtletone
« Reply #13 on: January 05, 2005, 11:43:24 AM »
ammitsboel wrote on Wed, 05 January 2005 11:06
Mike...
Not anymore. Now what I do is strip naked and crank up the volume. If the hairs on my body tingle, I know I have enough high end. If i'm doing low end heavy stuff, I require a girl to sit in with me to make sure the kick is hitting in the chest. For the most part, this technique works really well. It only gets ugly if the band wants to attend the session. Then I have to stock up on plastic covers for the chairs.
TurtleTone Studio
mastermind
« Reply #14 on: January 05, 2005, 11:47:47 AM »
TurtleTone wrote on Wed, 05 January 2005 09:58
doh!
Really?  Hmmm... time to put toilet paper over the tweeters on the Dunlavy's ....   Twisted Evil  Twisted Evil  Twisted Evil
t
trevor sadler
charlotte, nc., usa
Pages: [1] 2 3  All   Go Up
Page created in 0.108 seconds with 20 queries.
