The need for more and more gear just never seems to end......
I'm in the middle of my first mix that includes amplified bass since moving into my current space. In my last studio, which had a very large, acoustically balanced control room, my little Tannoy Reveals gave a good indication of the low end. Even sounds that were below the range of the Reveals were "hinted at" and I was never surprised when I took my mix to a system with big bottom.
But while I have done my best to treat my current room, the fact is that its a tiny little room and the low end response is not as clear as in the old room. I just listened to one of my current mixes in another room and heard several bass notes that just were not apparent on my system.
The only solution that I can think of is a sub-woofer. But I'm curious if even a sub is of much value in a very small room? Is there anyway to select a sub for a small room other than bringing it into the room and trying it out? Finally, has anyone tried the Tannoy 8" or 10" subs intended for use with Reveals?
