[quote title=danlavry wrote on Wed, 20 October 2004 18:28]
Terry Demol wrote on Wed, 20 October 2004 16:22 |
danlavry wrote on Mon, 18 October 2004 01:49 |
Hi Dan,
Interesting thread WRT low noise input design. If I may add some relevant info. You had mentioned the addition mechanism of current noise which manifests itself through the source resistor, this only applies to BJT (transistor) input devices. JFETs and tubes have virtually no input current noise. In absolute noise terms high gm JFETs are similar to bipolars WRT noise (0.7 to0.9nV/rt Hz) and there are actually some tubes which are not far behind at about 1.5nV/rtHz although these are all frame grid tubes and microphony can be a real problem.
Examples of JFET input pres are the very well regarded Forsell Fetcode pre and Manly SLAM.
Cheers,
Terry
As a rule, JFET technology is pretty noisy (voltage noise), compare to bipolar, and at low source impedance, bi-polars are much better overall. At high impedance FETS may be better, but we are talking about low impeadance application s (mic pre). Take a look at OPAMPs. It is the same problem! You can find a number of bipolar sub 1nVsqrtHz. Not a single FET input like that. If I recall, the pure JFET opamps are at best at 6nVsqrtHz and above, and the BIfets are a bit better. A 6nVsqrtHz compared to a 1nVsqrtHz is a huge difference (15.5dB loss in dynamic range), and at that point you would not even care about current and 250 Ohm source. Simply too noisy for a micpre...
BR Dan Lavry
Sorry Dan but this is incorrect. Please re-read my post as I
was referring to high gm JFETs not generic jfets. These
have nothing in common with noisier JFET IP opamps and AFAIK are
not suitable for IC fabrication.
As stated in my post they are specced at between 0.7nV/rtHz
and 1nV/rtHz input noise depending on models.
High gm JFETS have been used for 20 odd years in many high
performance moving coil phono stages. These have to deal with
signal levels much smaller than even low output ribbon mics
although in these applications they are usually paralleled to
get somewhere around 0.3 to 0.5 nV/rtHz (super low noise).
However non paralleled are fine for mic pre IP's to get EIN specs
of around -128dBu or better.
Here are some examples of low noise apps for JFETs:
http://www.royerlabs.com/SF-24.htmlhttp://www.forsselltech.com/fetcode.htmhttp://www.audioresearch.com/PH5.html http://www.stereophile.com/amplificationreviews/935/index2.h tml
http://www.audiophilia.com/hardware/phono1.htmThere are many more.
I have used them myself in all sorts of low level apps including
Ribbon mic pre's.
I am surprised you are not familiar with current low noise JFET
technology as they present some very interesting and specific
advantages for mic pre's but as always, some disadvantages.
They definately sound different to bipolar inputs, and as usual,
some people love 'em
... some don't
Best Regards,
Terry
