Jordan,
Oh, wow. Big questions. Let me see if I can help.
Jordanosaur wrote on Fri, 01 October 2004 21:46 |
I know that the single-bit DSD encoding process can acheive up to 2.8 MHz,
This is a little bit of a misnomer. The SACD spec requires that the data be sampled using only 1 bit, and that it do this 2.8224 million times per second. Many processes can "achieve" 2.8224MS/s, and DSD can actually "achieve" higher than that, if you will. The SACD spec defines what goes on an SACD disk, and that spec has determined that the material that qualifies as SACD is 1 bit, 2.8224MHz. This coincides with 64x the speed of sampling on a traditional audio compact disk.
Quote: |
and is claimed to be a superior conversion process over PCM due to lack of filtering and decimation involved during conversion.
Yes, there are people who claim that.
Quote: |
Here's my question(s): When the SACD media is printed, is the same one-bit DSD information printed onto the disc, or is there a downsampling process (not lossy compression) involved that allows that data to fit onto the physical media?
No, it is the 1 bit material. You ask if it is downsampled so it can "fit" onto the physical media. Well lets look at the numbers:
16 bit, 44.1KS/s means that every 44,100th of a second 16 bits are used. This means that 705600 bits are needed per second.
At 24 bit, 96KS/s (as DVDs are capable of) we use 24 bits every 96,000th of a second. This means that we use 2,304,000 bits per second.
At 24 bit, 192KS/s (as DVDs are also capable of) we use 16 bits every 192,000th of a second. This means that we use 4,608,000 bits per second.
For DSD we use 1 bit 2,822,400 times per second. This means we need 2,822,400 bits per second. Notice that that is LESS than 16 bit, 192KS/s requires.
Also remember that DVD disks (which is what SACD actually uses) is capable of much greater than this anyway. A DVD disk can spool off more than three times that amount of information per second. A DVD disk can spool off 9,600,000 bits per second, and this is approximately what is used with DVD video disks you buy, or with full surround material in uncompressed PCM format (24 bit 96KS/s in the front three channels and lower rates in the rear and sub).
So to answer your question, no downsampling needs to occur in order to "fit" the SACD material on the disk. The disk can actually hold about three times the data that SACD requires.
Further, DSD manufacturers WOULDN'T do this downsampling, because that would negate specifically the supposed benefits they claim above - that no filtering or downsampling is required!
Quote: |
The units that I am familiar with do contain a DSD decoding chip, but I am curious to know if this will be faithfully decoding DSD information, as opposed to decoding a lower resolution digital stream.
We need to know more about this "decoding" chip. My guess is that this is because when the material is put on SACD disks it is "scrambled," if you will, for the sake of error correction and copy protection. In other words, the data doesn't go on the disk as sample 1 goes first, then sample 2, then sample 3, etc. I am not sure exactly how it is done, but I have to imagine they take the first 64 samples as a chunk of data and then scramble that data in various ways before putting it on the disk - complete with a header for the "block." This is essentially what is done with CDs as well. Sample 1 does not go first, etc.
Quote: |
Other than that, any thoughts on the quality of the SACD?
Well, now, there's a big can of worms.
Quote: |
The common "audiophile" opinion is that SACD mixes promote less "fatigue" to the listener as opposed to the standard PCM format
Right. uh-huh. You betcha.
Nika.
