I would not pay too much attention to capsule construction. David's elliptical capsules have been around for a while, so if there were fatal design, construction or durability flaws in these capsules, they would be known (and probably corrected) by now.
Instead, I would start the decision-making process with intensive listening tests, and with a known high-quality mic as baseline constant and test comparator. I would conduct the tests in a listening environment, and on playback equipment, you are intimately familiar with.
In addition, to make the try-outs easier, David's distributor, Brad Lunde, is known for his generous return policy, if things don't work out so there is little risk of being stuck with a mic that does not perform for you.
I am confident that, after a thorough test under circumstances in your control, the relative advantages or disadvantages of these mics will become quite apparent, and a sound purchasing decision based on practical experience can be made.
