USED EQUIPMENT FOR SALE (SYNTHS,MICS,PREAMPS,MIXERS,CONVERTORS ETC)
Hi..i sell the following items in very good condition.Some of them are new-sealed.I can accept paypall.You can also check some ebay actions that i have.my username is sterg8.
i can send photos to everyone who is interested.You may think that my posts are suspect cause i list so many items but..iam not scammer.That's why i gave you all those infos about me.I can also make ebay action for the item you are interested but the price ll be little higher due to ebay fees!
email:
[email protected] MULTIFX-REVERBS-processors
-dynacord multifx Drp 15
-midiverb 2
-lexicon studio sound card (2 pcm90 onboard)
-yamaha e1010 analog delay
-drawmer mx50 de esser
-drawmer dl441 Quad Compressor/Limiter
-drawmer ds301 Dual MIDI Expander/Gate
VARIOUS
--SEAGATE MOMENTUS XT HYBRID 2,5'' DRIVE (SSD + SATA) 320GB
-anatek smp-7 midi patchbay-programmer
-anatek studio merger
-anatek rt 120 controller
-whirlwind multidirector 4 ch Di
-anatek all pocket series
-electroharmonix black finger dual valve compressor
-BEHRINGER MIDI-USB CONTROLLER bcf 2000
--4 GB RAM OCZ FATALITY OCZ3F1600LV4GK (2X2 GB)
-sony dat dtc690
-HHB PortaDisc Reporter's Kit (incl. MDP500, Sennheiser MD 46 +ALL ACCESSORIES)
-martin AQX analogue system controller
ARX
MULTI Q(Six Channel Parametric Equalize)
-I-Switch (12 Stereo Channel Step-Through Line Switcher)
-EQ 30 (Single Channel 'Constant Q' Third Octave Graphic Equalizer)
-EQ 130 (Single Channel 'Constant Q' Third Octave Graphic Equalizer)
- After Burner II(Dual-Channel Multi-Mode Compressor / Limiter)
-LEVEL 8(8 Channel Audio Balancer and Level Optimizer)
-ISO-Later (Single-Channel Transformer De-Coupler) :
-ISO-Later Duo(Dual-Channel Transformer De-Coupler)
-ISO-Balancer(Dual Channel Unbalanced to Balanced Line Converter) :
- ISO-DeBalancer (Dual Channel Balanced to Unbalanced Line Converter) :
- DI-6sm(Six Channel Active DI Box, Microphone/Line Splitter and Line Mixer) -
-COMPO(Enhanced Compressor / Limiter)
- Quadcomp II(Four-Channel Compressor/ Limiter)
-8-PRE (8-Channel Microphone Preamp) .
-BAR MIX (Multi-Media Zoner / Mixer) .
- SIX GATE(Six Channel Opto-Coupler Noise Gate)
-MAXI SPLIT(2 to 4 / 1 to 8 Line Distribution Splitter)
-MIXX MASTER(Six Input Mic/Line Master Mixer)
SONIFEX
- RB-RK1 (INTERFACE)
-RB-RK2 (INTERFACE)
-RB-RK3 (INTERFACE)
-RB-HD1 (Single Headphone Amplifier)
-RB-DA6G(6 Way Stereo Distribution Amp. with Gain Control)
-RB-SS10(10 Way Stereo Analog Source Selector/Mixer)
-RB-DA(6 Way Stereo Distribution Amp.)
-RB-DDA6A (6 Way Stereo AES/EBU Digital Distribution Amp.)
-RB-MA2(Dual Mic. Pre amp.)
-RB-SC1 (Sample Rate Converter 24 bit/96 kHz)
-RB-MM1 (Mix-Minus Generator)
-RB-SL2 (Twin Mono or Stereo Limiter)
MARTIN AUDIO
AQ 12
AQ 210
AQ 212
AQX
S 18
CS265
