Author Topic: AKG C414 tl-ii  (Read 3192 times)
radiovinhet
  • Real Full Name: Luis Fernando
AKG C414 tl-ii
« on: January 18, 2013, 07:12:39 am »
I have 4 akg c414 here... 3 b-uls and 1 tl-II...
I'm thinking to mod some of these mics.
Reading about C414 TL and TL-II, is correct to say that the only difference between these models is the capsule? tl-ii have ck12 nylon that tries recreate presence bump of the classic ck12 brass ring?
if i change tl-ii capsule with ck12 nylon b-uls, will have a c414 TL (the first version)?
second question... use tim campbells ck12 clone in tl-ii, i'll have great improvement?
klaus
Re: AKG C414 tl-ii
« Reply #1 on: January 18, 2013, 12:18:19 pm »
What is an AKG "tl-1"?
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
radiovinhet
Re: AKG C414 tl-ii
« Reply #2 on: January 18, 2013, 02:09:38 pm »
Sorry, it's just "C414 TL"... don't have 1... but is the first transformerless c414 version.
klaus
Re: AKG C414 tl-ii
« Reply #3 on: January 18, 2013, 06:24:50 pm »
That model does not ring a bell. Please post the exact AKG model designation.
Thanks,
KH
Klaus Heyne
German Masterworks®
Jim Williams
Re: AKG C414 tl-ii
« Reply #4 on: January 21, 2013, 01:48:49 pm »
The 414 TL was released a few years after the B-ULS model as a marketing tool to capitolize on the then fad of rejecting audio transformers.
It is an identical mic to the B-ULS model with one exception: the output transformer was removed and replaced with a 330 uf/50v capacitor. Any B-ULS model can be converted to a TL model with a couple of caps and a 47 ohm resistor.
The TL-2 model was released later using the 'c-12' style capsule with it's 10k hz rise, the B-ULS capsule is flat in comparison. The one variation they didn't make was a 414 with the transformer and a TL2 capsule. Any takers?
radiovinhet
Re: AKG C414 tl-ii
« Reply #5 on: January 22, 2013, 10:41:36 am »
It's easy to convert B-uls to TL? I'll try!
Jim Williams
Re: AKG C414 tl-ii
« Reply #6 on: January 23, 2013, 11:35:50 am »
Use a 47.5 ohm resistor and a pair of 270~330 uf/50 v caps. Afterwards you will need to retrim the power rails, re-set the voltage at the oscillator to 62 volts, + - .5 volt.
