Yeah. Gawrsh, this internot thingy sure is complimakated!
I know how to work e-mail too
Okay. The specific aspect of the 456 thread that I branched off with was a bit where I said, you could 'fix' certain things about certain over-hot DAW mixes by resampling- even if you were just 'bumping' the resampling a bit. Specifically, you can even upsample and kill a bunch of information IF it isn't really supposed to be there in the first place.
In other words- if you mix on an analog console, or master through analog gear, AND resample at pretty much your final output level, you are guaranteed to not have this type of distortion, because a properly working sampler WILL NOT encode information beyond the Nyquist limit. If it's working right, no matter what you put into it, you're not going to get anything out that'll clip the DACs. I think this is part of the reason Brad Blackwood can get really hot and lively treble without it being grating- he may be doing some of that in analog and resampling at 44.1K. In so doing, it guarantees he's not generating illegal data.
If you work in a DAW or otherwise all-digital, nothing is protecting you from putting on treble or gain sufficient to overload the DACs. Certain types of sound will be
(a) grating and obnoxious
(b) technically not legal within the constraints of a Nyquist-observing sampling system.
That's in spite of the fact that the actual samples can be represented within that system. The files that I submitted? Every one could be stepped down one LSB less than full scale, which would mean that technically the data would not 'clip'. Yet the result is still totally illegal within the theoretical system- represents values that can not be arrived at through correct sampling of an input waveform, no matter what input waveform you chose. It could only represent a waveform way hotter than the maximum theoretical limit of the sampler- and on playback, this of course distorts horribly.
I'm demonstrating that the danger point for this, when handling really hot high-frequency sound, is at least 4db down from full scale. That's worse than I expected, though I am using pathologically difficult sounds akin to hi-hats cranked through raw digital clipping- but these types of very high frequency transients are common in DAW mixes, I just made examples where it's impossible not to notice what happens.
I suppose I can turn around and ask a question in return. Within your understanding of digital audio, and given that it is possible to upsample digital audio with arbitrary degree of accuracy (assume perfect upsampling) and given that you have sample values that are not actually in excess of full scale- can you have information in a waveform that goes away when you UPSAMPLE? If so, what is it?
I have just proved that you can have information, easily generated through DAW processing, that does go away. I am proposing that this information is 'illegal' and could not be arrived at through direct sampling- and for that reason, it breaks the playback system of the DAC and reconstruction filter- and that this is undesirable, sounds awful and needs to be avoided.
If you're not cranking the treble and pushing levels to upwards of -5db RMS level in your mixing and mastering, you don't have to do a thing, as only serious DAW abuse causes this. However, I think that is more common than uncommon these days... you yourself may be doing it.
If you do- you could fix it completely, just by changing the sample rate of your stereo master to 44.099 and using high quality (such as sinc interpolation) SRC to resample it to 44.1K, which SHOULD be an imperceptibly insignificant change, not even a downsampling, but can clear the glare right up if you're causing it.
And that's where I came in- that is exactly the assertion I made in the other thread. It happens to be true- and the difference can be as extreme as 12db of 'illegal' energy removed, if you're really over the top with it. This can be measured. I measured it.
Another way this relates to tape machines is, tape machines also guarantee you won't have this problem- both by not having it in the first place, and by tending to roll the extreme highs where the problem would manifest. That's not a given, though- you can get illegal 44.1K content even off _vinyl_ if you sample at a very quiet level and then amplify. There's plenty of vinyl records that have information that would have to be restricted to fit onto CD. If you sampled them directly, the input filters get it- but if you sample them at greatly reduced volume, and normalize, you can end up with illegal data that overdrives the DACs even without having individual samples clipping.
