Nobtwiddler wrote on Fri, 16 January 2009 18:02 |
As an avid audiophile, with a pair of Wilson speakers, a Wadia CD turntable, Mark Levinson convertors, a pair of Cary Signature 8 watt SET tube amplifiers, two custom made Analog turntables set up in my apartment. TRUST ME, this can go much further $$$, then one can possibly imagine!
That being said..... The sound is truly AMAZING~! I wish everyone could hear this, cause it really is out of this world! You are totally taken in by the music, it's not just a background experince anymore!
The way it was when I was a teenager. Sadly enough it took $$$ to get me there again at this age. GO figure.
I am curious about your custom turntables.
I've noticed two things which are not in agreement with audiophile 'tradition'
first a heavy platter sounds better, but even if the motor is not working too well and slips.. I've read of people stating that heavy platters sound better because the speed is more stable, especially on heavy modulated parts..
I think this is wrong. My belief is that a thin platter resonates at an audible frequency and is more likely to go into a state of resonance than a heavy one..
the other one which nobody seems to agree with is that I believe a tonearm should have a high mass, at the headshell at least.
I sold my Technics 1200 because the light arm was coloring the sound and resonating..
Just shut off the amplifier and put your ear next to the tonearm and pickup... do you hear music coming out??
well. that means that much of the energy is being absorbed by and resonates through the tonearm!
the cheaper lenco with a heavy arm does not make nearly as much noise and it sounds better.. but it does rumble a bit.
the ideal would be to have a perfectly centred record on a thick and heavy platter. The tonearm should have a headshell with enough inertia not to absorb any transients and resonate below audio freq. and the arm should be long enough to have little error for tracking, and be stiff, light, and non resonant.
I think the light tonearms are needed mostly to compensate for poor pressings and warped records.. not so much for sound.
but that's my take on it.. in the future maybe I'll have time to build one too.
