Pages: 1 [2] 3  All   Go Down
Author Topic: Thin Capsule Diaphragms: Better or Worse?  (Read 23558 times)
Oliver Archut
Re: Thin Capsule Diaphragms: Better or Worse?
« Reply #15 on: March 28, 2008, 08:23:59 PM »
made by Gefell the same way they were for the KM53/54/56 microphones.
Hello David,
Gefell does not make capsules the same way Neumann did. The backplate is similar but the process is different how the nickel is made an then applied. They are close but not the same....
Best regards,
Oliver Archut
www.tab-funkenwerk.com
We are so advanced, that we can develop technology that can determine how much damage the earth has taken from the development of that technology.
compasspnt
« Reply #16 on: March 29, 2008, 09:33:37 AM »
What was the thickness of the (various) U-47 membranes?
Klaus Heyne
« Reply #17 on: March 29, 2008, 02:55:56 PM »
Average 8-10
Klaus Heyne
German Masterworks
www.GermanMasterworks.com
Huntlabs
« Reply #18 on: April 01, 2008, 11:37:15 PM »
Hi,
I've got a Stephen Paul modified C12VR.  I believe it has a vintage C12 capsule on it that Mr. Paul put a 3u diaphragm on.  It isn't a bad mic, in fact it is very nice.  I've mainly used it on vocals but I prefer a K47 capped Hamptone HTM12A.  I have a pair of the Hamptone mics.  Mr. Hampton let me borrow his C12 capped HTM12A and I liked that a bit better.
So I'm trying to decide what to do with this C12VR.  Should I have it re-skinned?  Should I just enjoy it the way it is?  I don't know the extent of the other mods that were made to the C12VR by Mr. Paul.  Reading through the posts about the characteristics of 3u skinned caps made me think of my mic and how it sounds to me.
Here is a picture of the cap:
 http://www.fenderforum.com/userphotos/index.html?recid=40557
Thanks,
John Huntsman
Portland, OR
John Huntsman
Portland, OR
Huntlabs
« Reply #19 on: April 02, 2008, 07:06:40 PM »
I added some more photos of the microphone.  Look for the C12 titled photos.  Based on the current C12 thread it appears the capsule is "at best a C414EB".
http://www.fenderforum.com/guestbook.html?user_name=Huntlabs
Thanks!
John Huntsman
Portland, OR
Klaus Heyne
« Reply #20 on: April 02, 2008, 11:55:37 PM »
Restoring your CK12 to factory skins after a Stephen Paul capsule mod is probably  impossible.
Every CK12 mod I have seen by him entailed some planing of the backplate mating surfaces.
My advice: enjoy the mic as it is, or sell it.
P.S.: Nice Rosewood Tele!
Klaus Heyne
German Masterworks
ricknroll
Re: How bout' them microns?
« Reply #21 on: April 03, 2008, 09:07:20 PM »
Klaus Heyne wrote on Sun, 16 March 2008 16:54
There are both fans and opponents of thin (3
Klaus Heyne
« Reply #22 on: April 03, 2008, 11:47:03 PM »
In my post I was referring to custom shops which supply thin diaphragms to third parties. i.e. aftermarket.
Sorry for not having been more clear in my wording. Yes, there are a few manufacturers who use thin diaphragms. Aside of GT, Lawson is another one of the more well-known manufacturers, so is Brauner who uses 4
Klaus Heyne
German Masterworks
Tony Merrill
« Reply #23 on: April 09, 2008, 10:26:58 AM »
Are thin film diaphragms better?
Wow.
Ready for liftoff? 3...2...1... Here we go!
Short Answer: Coming from the perpetuator of the company that pioneered lower mass large diaphragms back in 1984, my answer may surprise some folks out there...
Sometimes.
But first: to ask a question like this is not like asking "Apples or Oranges," rather more like "Red Delicious or Granny Smith?" For there is no "better" in my mind, only different flavors, or colors on the palette... Strat or Les Paul? Martin or Taylor? Countach or Testarossa? Hayek or Klum?  Twisted Evil
Actually, the question itself has very little meaning, because the diaphragm is only one part of a complex and (sometimes) finely tuned system. I've built capsules with thin (Mylar) films that I would readily put up against ANY microphone original or modified, yet I'm still wrangling with getting 0.4 micron film to sound completely stunning. Many times those mics would win, sometimes they would lose- Why? Every application is different. Every set of ears is different. I've worked on mics that I thought were deficient in some particular area, yet it was exactly the deficiency needed to compensate some vocalist's overemphasis in that area, and vice-versa and on and on. Anybody tasted the difference between a pie baked with Red Delicious and one baked with Granny Smith? How about applesauce with those same two? Different applications.
As is readily apparent by now,(to wit, the larger part of the Sino-based dreck swamping the market) there is a lot more to making a microphone sound really Good (musical, sexy, etc....) than just machining some parts and sticking them together. It's entirely all too easy to assemble a capsule with
thinner diaphragms that really doesn't please anyone. So, the passing of judgment on all thin film mics based on hearing one or two is truly premature.
As for the longevity/reliability issue, I've said this before in this forum - in all the mics I've had a chance to examine, I've never seen a thin diaphragm fail due to its inherent thinness. Physical violence (Overeager tech, Drummer, Gravity) or adhesive failure (usually due to physical violence) are the cause of 99% of diaphragm failures. Mylar(r) is a remarkably tough film, and as long as there's no mayhem inflicted upon it, the film itself holds up. Period. There are 1.5 micron capsules in rental situations that are now more than 22 years old and still going strong. 'Nuf said.
Transient response may or may not be the strictly correct term to use for the perceivable increase in definition and transparency (for example the difference between hearing individual raindrops and hearing basically white noise,) but it's the most likely culprit in my mind. Regardless of the fact that the air cushion behind the diaphragm is a major contributor to high frequency response in a pressure gradient capsule, there is the issue of
inertia. One can argue that, with the proper damping, the inertia of a more massive diaphragm becomes irrelevant; I would argue that with lower mass and lower inertia, not only can higher sensitivity to the more delicate pressure waves result, but less damping is necessary as well. I will leave it to the reader to draw their own conclusions about whether less damping is desirable, though I will point out that a rough analog can be drawn to negative feedback in an electrical circuit.
So why, you ask, did I say sometimes? Well, I've tried to use thin diaphragm mics on inferior instruments -- I got inferior results. Too much detail. Too much clarity. Too much inferior instrument. An SM57 turned out to be the deficiency that made up for the deficiency in the instrument. Of course this is the extreme, but serves to illustrate the other end of a Broad spectrum over which many different microphones apply.
On another hand, the most consistent response I've gotten from users has been along the lines of "the artist is going nuts, they've never heard themselves like this before" and as a result the performance they delivered was more inspired. On the bottom line, I think that's what recording music is all about; listen to any early Motown record - I hardly think an argument could be made for sonic superiority on "Tears of a Clown" but the performances (and the songwriting/arranging) made it a classic.
Jeez, if only they'd had thin diaphragms...  Very Happy
(And yes, CK12's can usually be rebuilt to stock specs even after a mod - it depends.)
Best,
Tony Merrill
Stephen Paul Audio
Tony Merrill
Stephen Paul Audio
www.spaudio.com
J.J. Blair
« Reply #24 on: April 09, 2008, 01:29:10 PM »
Edit: OK, here's the problem with anecdotal evidence: The tech misidentified the capsule to me as a K47, when it was in fact an M7.  The user of thin diaphragms had serviced the mic, but not touched the capsule, by request of the owner.  The PVC on the backside had failed, as happens with old PVC membranes.
My apologies to the unnamed repair person, who I did not name for the very reason that it was second hand info.
studio info
Audio Craftsman
« Reply #25 on: June 04, 2008, 08:15:53 PM »
Our Stephen Paul modded u87 sounds so much better than our stock u87Ai, especially for vocals and dialog.  The thinner capsule is not the only reason it sounds so good, but I believe it is the most significant factor.  Not always the right mic, but I almost always prefer the Stephen Paul mod to the u87Ai when an 87 is the right flavor.
-Randy Coppinger
Randy Coppinger, Audio Craftsman
“A hammer and chisel do not a sculptor make."
- Michelangelo
MDM,
« Reply #26 on: June 04, 2008, 08:18:24 PM »
wouldn't a thicker diaphragm behave more like a piston?
I must study politics and war that my sons may have liberty to study mathematics and philosophy .. in order to give their children a right to study painting, poetry and music.
John Adams (1735-1826) 2nd President, United States
J.J. Blair
« Reply #27 on: June 04, 2008, 08:49:18 PM »
Randy, out of curiosity, try using both head assemblies on one body, to eliminate the difference in amp circuitry as a factor.  I'm curious about what you hear in that case.
studio info
Audio Craftsman
« Reply #28 on: June 04, 2008, 10:20:37 PM »
What a great idea! I've never detached head assemblies.  I opened them up but it was not clear to me how to get them off/on.  Any tips?
- Michelangelo
seedyunderbelly.com
« Reply #29 on: June 05, 2008, 12:56:03 AM »
It is easy use soft hands. Unscrew the bottom of the mic pull of the body tube.
Pages: 1 [2] 3  All   Go Up
