Author Topic: "Low frequency Loop gain" question  (Read 1710 times)
zmix
« on: March 03, 2008, 01:06:10 pm »
Bruno,
I would like a bit of clarification... on Slide # 27 of this series it is stated:
http://www.hypex.nl/docs/Bruno%20Masterclass/Slide27.GIF
By "low frequency loop gain" do you mean some specific low frequency corner or overall closed loop gain (below 20kHz)?
If the answer is the latter of those choices, then would it be accurate for me to interperet this to mean "Limit closed loop gain to the same value as the open loop gain at 20khz"?
Thanks,
bruno putzeys
Re: "Low frequency Loop gain" question
« Reply #1 on: March 03, 2008, 01:44:39 pm »
If there's no way of making loop gain so large that distortion becomes entirely negligible, make the loop gain constant for frequencies <20kHz. It's a bit counterintuitive because there's a net increase in THD but the spectral composition seems more benign. Again, it's not scientific at all - I'm only saying that whenever I have had to put up with distortion, I had a subjective (=sonically speaking) preference for frequency-independent THD over somewhat lower but increasing THD. Saved the day a few times.
Warp Drive. Tractor Beam. Room Correction. Whatever.
Affiliations: Hypex, Grimm Audio.
KSTR
« Reply #2 on: March 03, 2008, 08:18:41 pm »
Would this work with off-the-shelf IC op-amps also, by shaping a noise gain compensation so that noise gain is parallel to open-loop gain, in graphical terms?
- Klaus
bruno putzeys
« Reply #3 on: March 04, 2008, 02:43:39 am »
A choke across the inputs of an op amp doesn't really sound attractive to me Shocked . Noise gain is called that for a reason. You'd end up with a 6dB/oct "red" noise source with tremendous DC offset and drift. Besides, if an IC isn't up to scratch it makes more sense to replace it by one that is. "Dirty tricks" like these are only worth trying if distortion levels are too high to be called negligible and there's no other option left.
« Reply #4 on: March 04, 2008, 12:22:12 pm »
Have you considered the phase shift caused by inadequate loop gain margin, since the open loop is typically 90' lagging?
This effect should be modest in most situations, but not zero.
