Author Topic: Why can i only hear from one side?  (Read 4887 times)
Sneaky
« on: February 24, 2008, 11:16:43 AM »
ok so i have a MXL 990 and i am running it through M-Audio MobilePre. evrytime i record then play it, i only hear from the left side. why is it mono???? i have asked around and maybe it is the interface?? i cannot understand why this is happening..idk wats the problem. is there ANYONE out there who can help???
iF YU N0T RAPPiN` B0UT LyFE'
DEN YU N0T RAPPiN` B0UT SHyT
MY MUSiK
blaugruen7
Re: Why can i only hear from one side?
« Reply #1 on: February 24, 2008, 01:52:11 PM »
you record with your microphone one track in mono at one time.
if you hear it after pressing playback on the left or right or somewhere in between depends on where you route your recorded track in your sequencer...
look out for a function called "panning"
Sneaky
« Reply #2 on: February 24, 2008, 05:28:53 PM »
okk well i got it sounding stereo!!
but y is it recording one track in mono at one tyme????
MY MUSiK
Malcolm Boyce
« Reply #3 on: February 24, 2008, 08:40:04 PM »
What software are you recording into?
When using one mic and input, make sure whatever you are recording to is set as a "mono" or single track.  If you have one mic plugged into the #1 input of the Mobile Pre, and you record to a "stereo" track, it will only be recorded to the left track.  Input #2 would go to the right track.
The Mobile Pre Control Panel allows you to "direct monitor" the left input to both left and right outputs, but this doesn't route the left input to both tracks of a two channel recording platform.  This may be where your confusion comes from...  sounds correct when recording but playback only comes from the "left".
Audioboffin
« Reply #4 on: March 09, 2008, 01:13:31 AM »
Mono is good dude, all the big time rappers record their vocals in mono.. mono is da money.. cos ALL da folks can hear ALL da rhymes!
Malcolm Boyce
« Reply #5 on: March 09, 2008, 03:59:29 PM »
Audioboffin wrote on Sun, 09 March 2008 03:13
... mono is da money.. cos ALL da folks can hear ALL da rhymes!
Correct...  Mono is da shiznit...
Page created in 0.054 seconds with 18 queries.
