In poking about in the CP Panning thread (C.P. Panning, late of the 12th Northumberland Fusiliers), I came across this quote which seemed to go largely uncommented upon.
compasspnt wrote on Mon, 04 December 2006 12:28 |
Thanks for mentioning this. The proper method of panning (or non-panning) does indeed let one "get away" with less of this silly notion so many seem to have of "carving out frequencies" in a mix.
And I don't know how I missed it back then, but I think it's worth discussing.
It seems to come up with some regularity (said the actress to the bishop) on the internets... this notion that mixing is about "carving out" frequencies to make "space" for the instruments with EQ.
and that one HAS to do this.
That everything needs 400 rolled all the way out.
That everything needs a high pass filter WAY up near its musical chin.
That everything simply needs to be EQ'd up the wazoo to sound "modern".
That it's up to the mixing engineer to assign each track its unique frequency range 'space' and that nothing else should intrude into this frequency range. (as if this is even POSSIBLE when more than one person plays the same NOTE, but...)
I was recently told on one internets forum that basically I was just old fashioned (well, OLD) and that "heavy guitars" or "heavy music" HAS to be done this way.
I'm not at all a purist and I have NO objection to EQ, sometimes a LOT of EQ, if it's called for.
But I don't at all get this sonic real-estate approach to mixing.
It strikes ME as unmusical.
I tend to think more like an arranger or orchestrator.
I might decide to double the flutes with the violins because the combination is an appealing texture.
If I double them again with the violas, at the top of their range, that's yet ANOTHER sound. Yet they're all in the same frequency range.
If I decide to put one up or down an octave, that's a DIFFERENT sound.
But the idea is that the combination of instruments on a part or in a range is what gives the music its texture and flavour.
Separation of the parts isn't the idea. Even if it WERE possible.
I think there is SOME point to thinking about not piling on all the same frequency boost on everything, but that's an extreme in the OTHER direction.
I wouldn't add 3k to EVERYTHING, but I also wouldn't make it a rule that only ONE thing can have 3k added to it.
So, I'm free associating a bit, but I think it's worth discussing.
so?
oh, and I ALSO think that the axiom that "it's better to roll out than to boost" is complete bollocks.
discuss.
or not.
I don't care.
really.
