scottoliphant wrote on Fri, 01 September 2006 12:48 |
so, I'm a bit confused. I've seen folks use interchange the words polarity and phase. Are they not two different things? (a search here on the forum led to more confusion due to the above).
Polarity and phase are most certainly NOT the same thing.
Polarity is neither time- nor frequency- (which are really the same thing) dependent.
Quote: |
My otari tape deck is pin 3 hot (and have wired my cabling to reflect), but if i plug pin 2 hot cables in both input and output, my phase still appears correct, and I'm hard pressed to notice anything different about the sound, but something must be happening? thanks in advance
Assuming that you're talking about balanced cables wired straight through (pin 1 to 1, pin 2 to 2, pin 3 to 3), there's no such thing as a "pin 2 hot" cable.
Consider: your tape deck is connected to a balanced console. Therefore, it doesn't matter whether the tape deck is pin 2 or pin 3 hot. For example, assume that you're hooked up to a console whose I/O is pin 2 hot. The pin 3 hot input stage will invert the polarity (NOT THE PHASE) of the audio signal before it gets printed to tape. On playback, the pin 3 hot output stage drives whatever signal it gets from the playback electronics, but the pin 2 hot input stage of your console will invert the polarity again, resulting in a non-inverting signal path and all is well.
-a
