Swane wrote on Tue, 15 August 2006 15:11 |
Hi! Have anybodby else had any similiar problem? It creates DC errors and distort from time to time.. I have tried the Lavry support but no answear...
Cheers Swane
We have not seen your report on support, unless you sent it yesterday.
I never heard of DC errors. There is a setting for DC filter on, and that is the setting you want to work with. The DC off is used in the factory as part of the calibration process.
You can call in for support, and if you are reasonably sure the problem is with the converter, we will give you an RMA and look at the unit.
Our tech support is very responsive. Something must have happened to your inquiry. Maybe some Internet related issue? I will try and figure it out.
Regards
Dan Lavry
