Author Topic: 96k or 88k  (Read 11165 times)
cerberus
Re: 96k or 88k
« Reply #15 on: June 29, 2006, 12:13:37 PM »
Revolution wrote on Sun, 25 June 2006 21:38
After trying all of these sample rates even 192 I am now sold at 96K.
i was mastering last week at 88.2kHz and i switched waves lnmb from native to the apa hardware version (5.2) which does 2x internal upsampling at the moment (wheras the native version (5.0) does not internally upsample. )  apparently most people don't notice, but suddenly in a certain context, the difference was like night and day.
dan has a theory i understand.. so i don't know why i heard what i did ... and i am not in the mood to go 192 at the moment, in fact i can't afford to. so this is not what  i want to observe.  but it  seems reasonable to me that 384khz internal processing (around 4x my current working rate) could sound even truer to the source.
jeff dinces
danlavry
Re: 96k or 88k
« Reply #16 on: June 29, 2006, 01:35:55 PM »
cerberus wrote on Thu, 29 June 2006 17:13
jeff dinces
When your material at some sample rate, then upsample it, the audio bandwidth content does not increase, nor is there "new music" or "new higher harmonics"...
So in theory, you gain nothing.
In practice you may gain or loose, depending on the specific gear. Remember that 99% of DA's will do upsampling to a much higher rate.
So when you allow the software to upsample by say X2, the DA does not have to do the first upsampling stage (which is the more demanding stage).
There are at least 2 places to look at:
1. Which sample rate converter is better? The software or the DA internal SRC.
2. How does the DA perform when fed various sample rates?
So it is all about the implementation - how does the specific audio chain work at different settings.
Regards
Dan Lavry
cerberus
Re: 96k or 88k
« Reply #17 on: June 29, 2006, 05:17:35 PM »
danlavry wrote on Thu, 29 June 2006 13:35
i understand that there should be nothing wrong with 44.1 source files assuming the converter was properly designed. but each generation of converters seems to raise the bar for this. i notice you are still making improvements in your designs and seem to offer at least two quality levels (blue,black). so that suggests to me that converters are not nearly perfected yet; and thus  perhaps it's safer to record at higher rates at this moment, even with the best converter made.  is that a fair assessment?
jeff dinces
Pingu
Re: 96k or 88k
« Reply #18 on: July 04, 2006, 04:44:02 PM »
What does the AD have to do with a plugin upsampling for processing?
If I defend myself I am attacked. But in defenselessness I will be strong, and I will learn what my defenses hide.
mpd
Re: 96k or 88k
« Reply #19 on: July 05, 2006, 10:26:13 AM »
cerberus wrote on Thu, 29 June 2006 12:13
What were you doing when you noticed the difference?  I have been meaning to work out the math, but I can think of two situations where internal interpolation can make difference.  Both have to do with implementation of IIR filters.  Basically, the same filter parameters will result in different tranfser functions in the z-domain at different sampling rates, which could result in audible differences.  This is different than running the converters at a higher rate, though.
cerberus
Re: 96k or 88k
« Reply #20 on: July 05, 2006, 01:59:12 PM »
mpd wrote on Wed, 05 July 2006 10:26
i was literally attempting to free up some cpu on the computer...i was not listening for nor expecting any audible difference, which is why the event was so striking to me.   the plug is a multiband compressor/ expander with adustable response profiles (e.g. knee) and f.i.r. (linear phase) crossovers.  on that project i  used it as a  low level expander in an m/s array.
jeff dinces
Ronny
Re: 96k or 88k
« Reply #21 on: July 06, 2006, 09:18:01 PM »
blueintheface wrote on Mon, 26 June 2006 08:01
kraster wrote on Mon, 26 June 2006 12:24
Well Pingu did say that his ultimate destination is Cd so SRC is pretty relevant.  Wink
Personally I think that recording at the Sample rate of the ultimate destination is the best way. I try to avoid SRC when at all possible. And, in my experience, the benefits of recording at high sample rates are lost/altered when downsampling from a higher rate.
I guess the irony didn't translate - I agree with you that good SRC is vital, and generally best avoided altogether.
I'm also a fan of blind listening tests.
Been there too many times twiddling a knob that wasn't connected to anything - until it was in the position that just 'felt right'.
People in general seem to have a hard time accepting that psychology plays a huge part in aural perception - and it's so easy to prove.
You won't find me in that camp, 90% of the misinformation that you hear on the internet is because people trust their ears too much and don't take into consideration sensory inhibition. Basically they don't confirm with the science, what they think their ears are telling them. Our perception can change from day to day and even hour to hour and our senses cross reference each other. For example the olfactory gland (nose) plays a huge part in how good or bad different types of foods taste, take that away with a cold for example and all food tastes bland. The taste buds haven't changed but the nose is clogged so it doesn't do it's normal cross sensory job. ITR, the eyes affect the way the auditory cortex receives audio information. Human elements such as mood, how fresh the ears are or how fatiqued they are, how much coffee you drank that day, how loud or low the music was that you were listening to previous to the test, how much cerumen is present in the ear canal, are you presently happy or pissed off at the boss, fought with the wife that morning, IOW emotion and a host of other physical factors that sway validity and have people coming up with all kinds of stuff that can be easily proven in the blind tests.
I guarantee you that if you don't confirm what your ears hear with blind tests and start performing them, you'll realize in a short time that the ear may be a great device, but the auditory cortex fails at being consistent and to top it all off, on the long term tests, the effectiveness of human memory and recall has a whole lot to be desired. Most blind tests bring up more questions than they answer, but it's the best that we have when you are audibly comparing sample rates, gear etc. and trying to eliminate psychoacoustic and psychosematic factors. The sighted tests always have some amount of expectations, these expectations can lead to imagination. Our brains are not perfect at consistent audio evaluation and when differences are very minute, the mind has a way of having some people hear things that aren't there. It's no surprise to me because I've been there done that and learned that my ears aren't perfect. I'm not afraid to admit it. There is really no such thing as a golden ear, all day, every day, all of the time. The science doesn't change from day to day, the human mind does, it's really that simple, confirm what your ears are telling you with blind, double blind when possible and null testing. You have nothing to lose and only more insight to gain, as to what is "really" happening.
Page created in 0.084 seconds with 16 queries.
