hello-
i just took in a new (to me) MTR90III. one of the audio cards isn't of the same lot as the others, it looks a bit older than the others, though same PCB#. i was switching SW101, the UNBAL/BAL switch over to UNBAL for my use on all the cards and noticed this particular older card does not have a conventional switch like the others, but rather a sort of makeshift jumper. there are 3 bumps, and a very lightweight jumper of what seems just slightly more sturdy than aluminum foil (though gold-ish in color) was connecting the poles together.
have you seen this in earlier versions of the audio cards, or do you suspect this a one-off field fix of some sort? my problem is after i moved it to the UNBAL position, it feels to me like it's just barely staying on. i did my best "re-crimping" with needle-nose pliers and trying to poke in with a screwdriver - but something just does not seem right about this connection.
thanks in advance,
