Author Topic: dB-4496 fan  (Read 2786 times)
Andrew Hamilton
dB-4496 fan
« on: March 20, 2006, 10:58:11 PM »
Yes, I'm a fan of the dB-4496 modular series.  But I was actually wondering if such a frame (housing two M*DA 824 and nothing else) could operate safely without the fan running, if the lid is off and the room is air conditioned.
_andrew
www.serifsound.com
premastering for CD and DVD-A.  Featuring FTP load in and delivery as well as analog tape transfers.
zmix
Re: dB-4496 fan
« Reply #1 on: March 21, 2006, 10:52:58 AM »
Andrew Hamilton wrote on Mon, 20 March 2006 22:58
Yes, I'm a fan of the dB-4496 modular series....
_andrew
To quote Groucho Marx; "If it gets any hotter, I could use a big fan"
PookyNMR
Re: dB-4496 fan
« Reply #2 on: March 21, 2006, 12:28:34 PM »
I'd keep the lid on to protect from dust...
I've got a fully loaded chasis in front of me here and have never had the fan running.  Never noticed a heat issue (not hot to the touch).
IIRC, I was told by the folks at Lavry to not worry about it unless your in a very warm room or the unit is next to other gear that runs hot.  You would be wise to confirm those statments rather than take my word for it.  E-mail the tech support at Lavry.
Fanless,
Nathan Rousu
danlavry
Re: dB-4496 fan
« Reply #3 on: March 21, 2006, 01:05:06 PM »
Andrew Hamilton wrote on Tue, 21 March 2006 03:58
_andrew
Hi,
You can operate the unit without a fan, completely loaded (say 8CH AD or 8CH DA or any combination) even at elevated temperatures. The fan was put there for extreme temperatures. I have not yet seen a case where the fan is needed.
Open the lid, look for the fan power connector. It is marked J2, on an L shape board in front of the power supply (red and black wires). Pull the connector out, and you eliminated the fan operation.
Regards
Dan Lavry
www.lavryengineering.com
Andrew Hamilton
Re: dB-4496 fan
« Reply #4 on: March 22, 2006, 01:22:07 PM »
Thanks, Dan, et al., for your replies.....
_andrew
www.serifsound.com
Page created in 0.051 seconds with 16 queries.
