Author Topic: AKG D19c rolloff ring causing dropouts  (Read 2805 times)
Nick Treweek
« on: March 10, 2011, 10:58:45 pm »
Hi guys, hope the migration is going well!
I've finally received a pair of D19c mics I bought overseas a few years ago and left with a friend.
One of them is behaving strangely...in the M position, the signal is strong and clear.
However just touching the ring is enough to make it drop out completely.  Turning it away from the M position also results in complete dropout.
As far as I knew, the filter ring is simply opening and closing the port...
Any idea what else it could be affecting in this case?
Cheers!
panman
Re: AKG D19c rolloff ring causing dropouts
« Reply #1 on: March 11, 2011, 02:15:20 pm »
Hi Nick,
Yes, you are right, the ring is just operating a valve and has nothing to do with the electronics. That means there is a short cut or bad contact somewhere.
Sounds like the capsule has gotten loose and when the ring is turned, it just triggers the problem, because the capsule moves and the wiring is affected.
Esa Tervala
